Clutch Line and Bleed screw
SO driving home last night and went to shift from 3 to 4 and the clutch pedal just stuck to floor. got under the truck and the clutch line to the slave had popped out of its holder. Tried to jam it back in but couldn't get it to go. Got it back home (tow strap). and tried to pop open the bleed screw to release pressure so I can put the clutch line back in to the fitting but, the damn bleed screw shears in half! See photos - So am I screwed here and half to drop tranny to replace the slave? Or do you think i can drill out the bit of bleed left or maybe wrench it off and replace the bleed screw?
Also not sure why the clutch line came off in first place, been driving it around for nearly a year with out issue (bought used). the fittings both look happy - see photos.
ItsAFord55
12-27-2015 07:11 PM
Brian Fulcher
11-03-2015 11:02 AM
kieferz28
06-05-2006 12:25 PM
