FICM
Old Dec 18, 2015 | 07:52 AM
oxt127's Avatar
oxt127
FICM
Yes another one.
Saw 47 for the first time this morning, it was right after start up and then saw it fairly often for the first 15 miles of my drive this morning. Usually see 47.5-48.5. I forgot to turn on the scan gauge before I turned the key this morning as I do often to check voltage when cranking. Temp was 38 this morning and it will be cold again over night this weekend to be able to check it nice and cold. I'm not one to spend money before I have to but this is an important piece. Truck is stock other than listed in my sig. Exhaust is stock but previous owner did remove the cat at some point. Battery volts was running around 13.5 and no electronic accessories to speak of.
If I do get it repaired now thoughts on the tunes from Ed? I do tow heavy at times so unsure I want to go with the atlas 40.
Old Dec 18, 2015 | 08:02 AM
WatsonR's Avatar
WatsonR
I see 47 pretty often and even a a 46.5 the other day and not worried yet. Ford says that 45 is the magic number. Some here will say they will change at 46, but 47 is still pretty good.
I run the Atlas 40 and a tow tune, gets great mileage now and before the Atlas 40, 12-13mpg, now I'm 14-15.5 in town.
Old Dec 18, 2015 | 08:25 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
47 volts is fine.
Josh
Old Dec 18, 2015 | 11:45 AM
oxt127's Avatar
oxt127
With the Eco or Atlas 40 will I need to have my current tunes rewritten?
Old Dec 18, 2015 | 11:53 AM
WatsonR's Avatar
WatsonR
No, they should work nicely together.
Fandini
Feb 17, 2015 02:49 PM
Bullitt390
Mar 11, 2014 01:45 AM
uncwgrad1
Dec 7, 2010 08:35 AM
jayc3169
Jan 1, 2009 05:06 PM
hdman6
15
Feb 15, 2007 02:54 PM
