Traction bar help
Old Dec 17, 2015 | 08:26 PM
dustinsheeler717's Avatar
dustinsheeler717
Traction bar help
Hellol FTE. So I'm wondering if anyone can help me out here. I'm wanting to fabricate some traction bars at work for my truck. 07 f250 6" lift. Does anyone have a write up on making a set or has anyone done them. How do I know how long to make them. Do I have to buy the brackets to mount them on or can I make them also. Just throwing this out there, if anyone has any suggestions I'd appreciate it.
Old Dec 18, 2015 | 08:46 AM
Jmoen7's Avatar
Jmoen7
park the truck level, many different mounting points. Decide what you want for brackets on the back axle, and frame. Mount them and then measure the bar size and decide the style
Old Dec 18, 2015 | 09:20 AM
Maxium4x4's Avatar
Maxium4x4
That is an open can of worms.... Do you have access to DOM tubing and do you Off Road? Several designs are available and several not so good. Main goal is to stop the axle from rotating with no binding. I like 2 points at the axle with a solid mounting or weld on, nothing shorter than 60".
Old Dec 22, 2015 | 08:45 PM
dustinsheeler717
Hey John I just saw your reply. What is DOM tubing?. And no I do not really off road. Mountain rides is about it. Honestly I want them for the looks and the added help. But I want to make sure I fabricate them right.
Old Dec 22, 2015 | 09:18 PM
Maxium4x4's Avatar
Maxium4x4
You do not want seam welded tubing, DOM is Drawn Over Mandrel, seamless.
Old Dec 22, 2015 | 10:48 PM
dustinsheeler717
Okay. Is there a certian inside diameter or o.d. that you would recommend? Also would you recommend buying brackets?
Old Dec 23, 2015 | 02:06 PM
NotURMailman's Avatar
NotURMailman
Improperly engineered add on suspension links can be a nightmare and open can after can of worms. Make sure you do some homework and do it right. You need to consider the arc of movement during suspension travel as compared to changes in leaf spring effective length and axle position motion as well as a lot of other factors. Not trying to discourage you, just want you to know that it isn't as simple as some people think it is.
Old Dec 24, 2015 | 01:24 AM
Will Bite's Avatar
Will Bite
I have a set of flight fabrication bars on my truck. If you need any measurements inbox me and I will help out.
Old Dec 24, 2015 | 01:26 AM
Will Bite's Avatar
Will Bite
This is a good place to get all the stuff you'll need. I found it after my purchase. www.ballisticfabrication.com
Old Dec 24, 2015 | 07:16 AM
87crewdually's Avatar
87crewdually
Don't know if you saw this. It's in the 7.3 section of the forum but should be similar if not the same.
Traction Bar Install
camodown
Dec 11, 2009 06:51 PM
countrysF250
Dec 3, 2005 07:15 AM
LedheadELH
Offroad & 4x4
Nov 12, 2004 04:23 PM
FFSpiel
Jul 4, 2004 01:52 PM
redpstoke96
Aug 29, 2003 02:59 AM
