Transmission
Old Dec 17, 2015 | 02:58 AM
Cody LaFata's Avatar
Cody LaFata
Transmission
Anyone have any advice on how to remove the trans cross member from a 1977 250 4x4 i have everything loose, just cant get the piece out of the frame
Old Dec 17, 2015 | 04:37 AM
gatorfor88's Avatar
gatorfor88
BFH and patience if you have all the bolts out.
Old Dec 17, 2015 | 07:33 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Rotate it, twist it, turn it. I mean like in a flat spin going out to sea, not roll it itself.
X2 have you double checked that all the bolts are out? It should slide forward between the frame rails, then twist a bit and come out.
I take it the motor, trans and xfer case are out?
Read this thread, he had the same issue. https://www.ford-trucks.com/forums/1...250-build.html
Post #78 is where the cross member stuff starts.
Old Dec 17, 2015 | 12:39 PM
gatorfor88's Avatar
gatorfor88
If I remember correctly it bolts up and through the top of frame too. But its been like 30 years since I worked on a 250 4x4. So I could be wrong. Be the first time in like 55 years. So I probably am not wrong. Usually I aint. Thought I was wrong once about 40 years ago but I was mistaken about it.
giftpak21
Jan 25, 2014 09:00 AM
CAMiniTruck
Apr 16, 2012 09:33 AM
88CougarCoupe
Jun 2, 2008 04:06 AM
fairlaniac
Feb 2, 2007 01:27 PM
Craigwell
Jun 30, 2004 09:34 PM
