Transmission
Anyone have any advice on how to remove the trans cross member from a 1977 250 4x4 i have everything loose, just cant get the piece out of the frame
BFH and patience if you have all the bolts out.
Rotate it, twist it, turn it. I mean like in a flat spin going out to sea, not roll it itself.
X2 have you double checked that all the bolts are out? It should slide forward between the frame rails, then twist a bit and come out. I take it the motor, trans and xfer case are out? Read this thread, he had the same issue. https://www.ford-trucks.com/forums/1...250-build.html Post #78 is where the cross member stuff starts. |
If I remember correctly it bolts up and through the top of frame too. But its been like 30 years since I worked on a 250 4x4. So I could be wrong. Be the first time in like 55 years. So I probably am not wrong. Usually I aint. Thought I was wrong once about 40 years ago but I was mistaken about it.
