I have an old 2 ton floor jack. It doesn't lift properly. It holds the fluid OK, so I figure it isn't a seal. Is there a way to bleed the piston to give it new life? Thanks!
I feel you may wasting your time. I needed to get my jack fix, but I could not find anyone to do the job. And I am in SoCal, meaning there is so many people here, I was sure I would find someone. You might get lucky.
I also looked for an American made jack, but could not find any for a reasonable price.
From: Bama Gal transplanted to the Pacific North West
Floor jack repair?
my hydraulic motorcycle lift was leaking the very slightest at the bleed down screw (the piece you tighten to lift, and loosen to lower).... i pulled the fitting, found one at a parts house that i could make work and tapped the hole a little larger...works like a charm now...
I JUST put my 4-ton jack in the shop to have it gone through at a place in Seattle (Jack's Inc.). I figure that it was getting old and it needed a tune-up as it was made in the '70's.
I have not picked it up yet but they say it will cost about $275.00!!!!! Yeeeeeowch! that is more than I picked the jack up for originally; but then again, I couldn't get a comparable one for that price either. I'll keep you posted...
