Leveling Kit on '89 F-250 2WD ???????
I want to install a leveling kit on my '89 F-250 2WD, single cab long bed. I want to do the coil spacers like these: http://www.ebay.com/itm/191676916476?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Would these be okay? Its rare I use this truck to haul anything heavy (that's what the 6.4L is for). I have access to a two post lift, to get this thing off the ground. I'm wanting to install them before I get new tires, so I can have the front end aligned w/ the spacers and new tires on. Whats the install procedure? What all will I need to complete this task?
From the looks of it, these spacers either fit in between the first set of coils or between the coil spring and the tower. Either way it seems to me you would need to jack the front end up from the frame to take the weight off the springs. Then either slip the spacers in between the coils, or unbolt the upper retaining clip and droop the suspension down far enough to get them in. Hope this helps.
I'm not sure the clip would fit. It seems the clip would hold the spacer in, but no clue what holds the spring in place.
That will mess up the camber pretty bad. I'm not sure much it would be able to be adjusted when aligning. I know others have had problems lifting these trucks and keeping tires from wearing. The twin i-beam suspension doesn't care for lifts.
Pstroker01
1999 to 2016 Super Duty
12-15-2009 06:49 PM
