Offroad & 4x4
leveling kit
Old May 4, 2004 | 10:07 PM
Muddr Trukkr's Avatar
Muddr Trukkr
leveling kit
i want to install coil spring spacers, 2". does this affect my camber/caster angle and will i need an allignment after, because of how it changes the ttb angle on my 88 f150?? i put a 6 inch lift on the truck but the front springs fianlly settled and it looks gay compared to the back.
Old May 5, 2004 | 06:23 AM
fishmanndotcom's Avatar
fishmanndotcom
anything you do to modify your suspension will alter your alignment.....so yes it will be off, but i dunno if it owuld be enough to have to get it re-aligned.
-cutts-
Old May 6, 2004 | 01:53 PM
LuLuGoin2ADiesel's Avatar
LuLuGoin2ADiesel
This may not be relevant, but I put 2" coil spacers on my old truck.......01 Ram Off-Road and it did help to get it aligned. It was off enough to make the alingment worth while. Especially since I put new tires on at the same time.
Old May 6, 2004 | 09:03 PM
MF11283's Avatar
MF11283
Ive got a 2WD twin I beam ranger that I just got done putting 2" coil spacers on, and the tops of my front tires were out farther than the bottoms, (dont know what thats called) when I took it to be aligned they had to buy some "alignment kit" because it was farther out of alignment than the stock setup could be aligned, it cost about 190 bucks to get the kit, install it and align it. but maybe its diffent for a F 150 vs a Ranger
Old May 6, 2004 | 09:50 PM
74F250's Avatar
74F250
that out of alignment kit is prolly the dop down brackets for the middle..i woudl suggest buying those if you level it with a spacer or coils
Old May 6, 2004 | 09:53 PM
MF11283's Avatar
MF11283
it was actually something that went on the end of the I beam where the spindle, (at least what I would call the spindle) is bolted on, on the top and the bottom was left stock, they told me it just gives it more play so they can align it farther
Old May 6, 2004 | 10:40 PM
hoxiii's Avatar
hoxiii
it's a set of eccentric camber bushings that are more eccentric than stock. they cost about $60 if you buy them outright.
Justin
Old May 7, 2004 | 09:45 PM
74F250's Avatar
74F250
adjustble camber bushings for us idiots, you would get better flex though if you did the drop down brackets
Outlaw56
Feb 25, 2017 05:22 PM
Jointasset
Jul 5, 2016 08:24 PM
bulletsneverlie
May 29, 2010 04:22 PM
richsoucie
Mar 3, 2009 10:15 AM
wileec
1978 - 1996 Big Bronco
May 15, 2002 03:44 PM
