Doing the twist. :O
This is my 1989 Ford F-150, 4x4, 351W, 3-speed A/T (C-6), Ford 8.8 w/3.73 LSD, Lock out hubs, Towing package, XLT, Reg cab, more useless info available upon request.
After replacing the steering sector / gear box. It rode very well.
Though some weeks later it became apparent the steering wasn't quite right.
Eventually it was so lose I decided to check the ball joints.
All seemed OK. So my dad turned the wheel back and forth while
I watched from under the truck.
Much to my dismay the frame was twisting a lot, also the
steering sector was almost falling out. The bolts holding it
in were about an inch out of their holes.
We tightened those immediately. Also getting some high grade
lock washers.
The trouble is the frame still has an excessive twisting issue.
What is going on? There are 3 videos attached. Please be sure
to watch the 3rd one. 15 seconds in you will see 2 rubber pieces.
They start out inline with each other, but then ... I'll let you see.
BTW, the frame is largely free of rust. As is the rest of the truck. Any good guesses are very much appreciated!
Thank you!
View of the steering sector's section of frame LH (left hand / driver's side). Shot from the truck's front LH corner.
View of the shock tower from the truck's front LH corner.
Watch for 15 seconds in! View down the rail from the cab toward the front of the truck. LH side rail.
Look at your 29 second video and watch the crack open up along the bottom frame flange between the two steering box bolts at 0:06 and again at 0:20.
There is a lot of frame movement going on that would not be going on if you had any structural integrity. Probably a lot more going on under here, but you need to disassemble and inspect.
If you'd just get under it while someone rocks the steering wheel back and forth (as stated in your other thread no need to go full lock to lock) have someone rock the wheel right and left while you look everything over real good using a flash light, you'd see exactly where the problems are if you'd take a few minutes to do that.
Appears in the video as the rear rivet is broke or its hole is wallowed out allowing for movement there (hard to say for sure going by nothing but that short video.
When one aspect of a given structure fails excessive stress is put elsewhere and then it gets weak and fails.
Your videos don't show much, time is lost to waiting for wheels to change direction return from full lock before deflecting frame again.
The damage is going to be more extensive than that, its broke on the inside of the frame as well, it moves way to far to be limited to what is showing from the outside of the rail.
You're gonna have to get under there and look then decide on best way to fix it, gotta say based on your posts here? you really should get someone that knows what they are doing to look at it. Its a safety issue it has got to be done right and chances are its a one time shot if any hope of saving that frame.
You need someone with the know how and equipment its gonna require to fix it right.
As for the taking it lock to lock. We did it to impart the greatest force on the system. The pump spikes to nearly 10 times the usual PSI when one does that. Not great for the pump, but I needed to get to the bottom of this issue. Even at the pump's expense.
While I do have a lot of experience working on vehicles. A frame repair is not in my comfort zone. Though I can prepare it with a ton of grinding, etc...
Perhaps there is a kit? Or just a new section of frame.
Also, don't grind on your frame and try to prep it for repair. Unless you just mean cleaning it up. But don't vee out the cracks for the welder, let him do it himself.
Some idiots didn't want to buy a real plow mount, so they welded a section of C-channel inside the frame rails. I ended up doing a lot of cutting to make it so the bumper would sit half ways normal.
Last craigslist truck I buy.
BUT, what years can I use?
Hope a 96 F-350 is not compatible. Just parted one out and sent the frame away.
You SHOULD be able to use any 97-96 F-150 4x4 frame with the same wheelbase as your truck. Someone will correct me if I'm wrong about this.
And they are double wall up front around that.
https://www.youtube.com/user/FargoFord/videos
