Expedition 4wd problems
Old Dec 13, 2015 | 04:07 PM
BadBee's Avatar
BadBee
Hello Men,
I just picked up another 2000/-4.6 Expy with190k on it motor runs good,body great but tranny shifts into 4L 4H no problem,when I go to AWD I still feel the front axle engaged,also after checking the compass/temp light on overhead dash is out. Are they related? It feels as if there is restriction on the front axle, at high speed it peters out! Any and ALL help is APPRECIATED
Thanks,
Mitch
Old Dec 14, 2015 | 08:32 AM
meborder's Avatar
meborder
Welcome to the forum!
If I recall, the front axles on that generation is always engaged, regardless of the switch position.
If you think there is something wrong with the front axle, you might have to jack the front end, drop the front drive shaft and spin it by hand.
There could be a problem, but having driven quite a few 4.6 powered vehicles, including an f150 of that vintage, I feel pretty comfortable saying that high speeds aren't their strong suit. just something to consider.
good luck!
Post up some pics! we all like pics!
Old Dec 14, 2015 | 02:35 PM
alloro's Avatar
alloro
By "engage" I think he means powered...but that's my assumption.
Old Dec 14, 2015 | 07:19 PM
BadBee's Avatar
BadBee
A4WD
Thanks Guys for the welcoming!
This is #2 2000 4.6 for me and the reason I got it was for fuel economy going back and forth to Maine with my Bird Dogs.
But the problem as of today is it seems that the AWD is fully engaged as if it was 4WD Hi or Lo.My plan tomorrow is to check fuses,vacuum leaks and then on
Ramps to check to see if shifter motor is ok,and to see if rod is engaging or disengaging, I can hear the switch working inside the dash when operated ad hear a noise (sometime) underneath. Start is fuse #23 as my Compass/Temp
Readout is not working .ANY HELP IS WELCOME AND THANK YOU!!!
Mitch
Super5.4
Oct 29, 2016 10:09 PM
twestfl
Aug 18, 2008 11:26 AM
polcat
Jan 17, 2008 07:57 PM
alan911sc
Mar 28, 2005 09:06 AM
johnitahoe
Jan 4, 2005 08:37 PM
