Two questions!
Old Dec 13, 2015 | 07:33 AM
bobs 80 f250's Avatar
bobs 80 f250
Two questions!
I have a 1980 F-250 camper special
1. Why are LED's positive and negative sensitive? Just changed cab and visor lights to led and found this out before final assembly. Saved me some aggrevation!
2. Want to add a third brake light into my cargo light assembly. Will look at a later 80-90 from a jy. What am I up against? Will it be a pita to run a wire for the brake light?
Old Dec 13, 2015 | 07:45 AM
Gary Lewis's Avatar
Gary Lewis
LED's are a diode - Light Emitting Diodes. And diodes only conduct in one direction - positive to negative.
As for the cargo light, it isn't running the wire that's the biggest issue, but the fact that the cab has to be cut to accept the wider assembly.
Old Dec 13, 2015 | 07:50 AM
ctubutis's Avatar
ctubutis
Two answers!
1) LED = Light Emitting Diode - a diode is an electrical valve that lets electricity flow one direction but not the other.
2) I suggest tapping into the circuit at the brake light switch on the pedal; beyond that point, power gets distributed and manipulated by the turn signal switch which will flash power to either or both sides in certain conditions.
Old Dec 13, 2015 | 07:54 AM
Gary Lewis's Avatar
Gary Lewis
Here's a link to where I cut out Dad's cab to accept the larger light: https://www.ford-trucks.com/forums/1...l#post13786381
Old Dec 13, 2015 | 11:18 PM
bobs 80 f250
Thanks for the info. I had asked an electrician buddy of mine,but he couldn't really tell me why. As for the light.........there's always next summer. Just got the truck back from paint and finishing up putting on some the hardware. Will have pics soon!
F-250 restorer
Nov 19, 2018 09:48 AM
island eddie
Electrical Systems/Wiring
Nov 17, 2017 09:33 PM
78fordguy
20
May 5, 2015 02:11 PM
largefries
Sep 28, 2007 05:16 PM
MemOrex
Sep 30, 2004 08:03 PM
