Sponsored by: Real Truck
2004 F250 brake light problems.
Old Dec 11, 2015 | 09:26 AM
GM4WALLS's Avatar
GM4WALLS
The flashers and blinkers work, the taillights, brake lights and back up lamps do not.
The truck is a 2004 F250 4x4... Checked all fuses. What am I missing?
Old Dec 11, 2015 | 02:11 PM
droldsmorland's Avatar
droldsmorland
Start with the Bulbs. The on to the sockets, wiring and connections in the harness.
Old Dec 11, 2015 | 02:15 PM
GM4WALLS's Avatar
GM4WALLS
All bulbs are new, the blinkers and flashers work (same bulb and socket as the brake and tail lamps). I might also add that when hooked to the trailer, the brake and tail lights do not work on th e trailer either. So the truck is clearly not sending the signal.
Old Dec 11, 2015 | 06:13 PM
Dillon Ance's Avatar
Dillon Ance
there is a sensor under the brake pedal. Nuetral stop switch or brake switch sensor or something similar. Ive replaced a few on 04's especially expeditions
Old Dec 11, 2015 | 06:23 PM
2001F350dualwheel's Avatar
2001F350dualwheel
Did you check fuses
Otherwise
Brake switch
Reverse switch
Headlight switch
Brake and reverse switches could simply need to be realigned/repositioned. Some have a rubber snubber which falls off or gets squashed
Old Dec 11, 2015 | 06:59 PM
GM4WALLS's Avatar
GM4WALLS
I will have to check that out. Seems like regardless, the tail lights would illuminate when the headlight switch it turned on.
Old Dec 11, 2015 | 07:09 PM
2001F350dualwheel
Yeah but if your headlight switch is burned out there won't be power going to the lights
Old Dec 11, 2015 | 07:12 PM
GM4WALLS's Avatar
GM4WALLS
But would the headlights still work?
Old Dec 11, 2015 | 08:24 PM
2001F350dualwheel
It's possible. Your headlights and parking lights run on a different circuit. Are your interior lights working? Could be a lot of things from a fusible link to a bad ground to a bad multi switch,
I don't have a manual but looking at various schematics looks like parking lights may be on a fusible link and headlights on a fuse
Old Dec 12, 2015 | 08:21 AM
GM4WALLS's Avatar
GM4WALLS
That's a possibility. Will have to check that out. The parking lights are not working either. As for the interior lights, not sure. It's a company truck, I do not drive it regularly.
romanelli
Feb 7, 2018 02:26 AM
bigcrunch
Feb 3, 2017 02:06 PM
Andy chavez
Aug 26, 2016 03:54 PM
projectdagger
Nov 19, 2012 05:35 AM
bibababy
Mar 11, 2012 06:10 AM
