Brake lights not working
Old Aug 25, 2016 | 02:46 PM
Andy chavez's Avatar
Andy chavez
Brake lights not working nor is the hazards on a 1983 f250 the hazards just stay on no blinking anyone know how to fix it
Old Aug 25, 2016 | 06:10 PM
maytag906's Avatar
maytag906
Hazard lites inop is probably a flasher unit.
Old Aug 25, 2016 | 08:50 PM
Andy chavez
I found out that the brake light switch melted together and was always on. I fixed the wires now brake light on right rear work but the left side does not. I even replaced the bulb. Now I'm looking on wiring diagram to trace the left side to see why no power to that side.
Old Aug 25, 2016 | 08:55 PM
ctubutis's Avatar
ctubutis
Jiggle the turn signal switch while stepping on the brake and see if it magically comes on.
Old Aug 26, 2016 | 03:54 PM
Franklin2's Avatar
Franklin2
Yes, if you follow the diagram back you will hit the turnsignal switch. If the blinker works for the bad side, then you know the bulb and the wiring to the rear are good, since the brake and the turn use the same wire and the same bulb filament.
1997fordf350
Jul 8, 2013 01:54 PM
breadstick
13
Mar 19, 2012 08:32 PM
weldworks54
15
Jun 27, 2010 06:36 PM
packrat56
13
Apr 6, 2004 06:31 AM
jml
Jan 29, 2002 08:40 PM
