Been enjoying the new W/B Mod springs on the Ex. I've had a couple issues with noises, both clunking (sway bar links), and also going over bigger bumps like speed bumps, or anything where theres a lot of flex, it has a bit more noise. Not sure if something is loose and cannot seem to find anything.
I did have the tie rods replaced when I got it aligned, but those also look good.
Any common culprits for what could be causing the noises when going over larger bumps? I shot some teflon spray on the plastic discs on the springs to see if it's coming from there. I also though it may have been bottoming out on the aftermarket bump stops, but that's not the case.
