V/B mod question
Old Dec 12, 2017 | 10:38 AM
03X's Avatar
03X
V/B mod question
Hi all
I have done the V/B mod, skyjacker m95 shocks in the front and monroe reflex shocks in the rear.
I feel as though it sits nose-down quite a bit, and also I still feel the front is a little soft/bouncy.
Should I be looking at firmer shocks, or doing an add a leaf in the front, or just a piece of a leaf to bring the nose up a bit?
What have yall done to yours?
Old Dec 12, 2017 | 11:10 AM
csnow's Avatar
csnow
Originally Posted by 03X
Hi all
Shocks will not raise it in the front but it could cause your "soft/spongy" feeling. I only use Bilstein shocks. No offense, but skyjacker is not known for high quality. What brand springs did you use?
Old Dec 12, 2017 | 11:18 AM
ithaca1230's Avatar
ithaca1230
My ex sat the same way after I replaced the springs with V&modded B. Went back and put the stock leaf (it was the last loose one) from the rear in the front and that helped. It still sits a little higher in the rear but when I put a trailer on it sits flat.
Old Dec 12, 2017 | 11:27 AM
03X's Avatar
03X
I used ford springs from the wreckers. The v-codes were like new, the rear b-codes had a lot of surface rust but in much better shape than they appeared. I could not have asked for a better ride in the rear, very happy with it. Just the front seems a little off/soft. Not sure how much firmer a bilstien would be compared to a M95 in the front?? And also not sure if I need a firmer shock or just a bit more spring.? An adjustable shock maybe?
Old Dec 12, 2017 | 01:22 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Hi all
You are talking about 2 seperate issues.
The "soft/bouncy" is a shock issue. Solution, use a shock with firmer valving
"Nose down" is simply a ride height height issue and there are several solutions to that depending on what you are trying to accomplish.
Step on, Measure each corner of the vechile from the center of the wheel him to the bottom of the fender arch and post your results.
Once we know the actual measurements also let use know how you would like it to sit appearance wise but also how you intend to load and or tow with it.
Old Dec 18, 2017 | 08:30 AM
03X's Avatar
03X
Well after a couple weeks of driving I would say I am looking for a slight lift in the front. Too much "rake" for my liking. I would say like a 1/2" or 1" lift in the front would be perfect. And what shock part# from bilstien is recommended? Not looking for harsh ride but firm enough to notice an improvement from the M95. The M95's are wonderful on the highway but feel too soft/body rollish when going over large bumps or even smooth dips in the road. havent had a chance to measure anything yet.
Old Dec 18, 2017 | 06:02 PM
wpnaes's Avatar
wpnaes
The level kits are available from many mfgrs.
Or go the Brent route.
https://www.ford-trucks.com/forums/1...-pictures.html
M3rc
Jul 22, 2019 11:08 AM
03X
Dec 8, 2015 03:41 PM
juddspaintballs
Mar 19, 2015 07:24 AM
jeff8362000
Nov 19, 2009 12:44 AM
DOUBLEF222
Mar 2, 2008 08:36 PM
