Sponsored by: Real Truck
Strange t case problem
Old Dec 10, 2015 | 01:52 AM
t-loc1's Avatar
t-loc1
I have a 2001 F350 with a7.3 power stroke, 6 speed manual with manual t case and hubs. I have a bad grinding noise when in 2 wheel drive. Similar sound as if you are trying to shift t case into 4 wheel drive too slowly. The grinding is constant in 2 wheel drive, but if I shift it into 4 wheel drive, the noise completely goes away. I have been driving around in 4 wheel drive (T case only, manual hubs not locked) for the past 2 days. If I shift back into 2 wheel drive, a constant terrible grinding noise returns. Any thoughts on what could be wrong, and why it goes away in 4 wheel drive?????
Old Dec 10, 2015 | 05:08 AM
senix's Avatar
senix
has to be a bearing or something.
Lets start at the basics. When was the last time you checked or changed the t-case lube?
Old Dec 10, 2015 | 07:43 AM
Tom's Avatar
Tom
Sounds typical of bad needle bearings in your front hubs. When the front driveline is disengaged the half shafts are completely stationary as long as the hubs are unlocked. The ends of the shafts ride in these bearings as the hub spins around the stationary shaft. When in 4WD the shaft and hubs are locked together, so the bearings aren't spinning.
You can lock the front hubs and disengage the T-case to confirm, this is how most people drive until they can get the bearings fixed.
Old Dec 10, 2015 | 09:17 AM
t-loc1's Avatar
t-loc1
Thanks Tom! I thought it initially sounded like a bad hub when I heard the noise, but was confused when shifting into 4 made it go away. Figured it had to be a problem with the T-case instead. You might have just saved me from unnecessarily taking out my T-case! Thanks!
Rannoch
Dec 22, 2016 01:47 PM
t-loc1
1997 - 2003 F150
Dec 10, 2015 09:20 PM
paul.meredith
Mar 4, 2011 09:42 AM
94F350IDI
Jan 20, 2009 07:10 AM
rosco_p_coltrane
May 14, 2006 01:45 PM
