front end problems
Old May 14, 2006 | 06:42 AM
rosco_p_coltrane's Avatar
rosco_p_coltrane
front end problems
I'm throwing this question over here since it has the same drivetrain and there are twice as many people...I've got a 03 Excursion 4x4 with 47k miles. I drove about two hundred miles yesterday and after the trip I made a u turn and herd only what I can describe as a popping sound that could be felt through the wheel. The four wheel drive was not engaged. I put it in four wheel drive, drove for about a quarter mile then took it back out. Noise gone. Any ideas? I also notice a few months ago when I parked on the ice covered driveway in two wheel drive, the truck started sliding backwards, but the front wheels did not spin freely. I'm thinking that the problem my be a bad vacuum solenoid causing the front drivetrain to engage without the transfer case, or maybe a sticky hub? Any input is appreciated.
Old May 14, 2006 | 07:00 AM
dmp437's Avatar
dmp437
Congradulations, you're now a member of the "Hub Club". One of your front hubs was locked up when you turned a corner and the popping you heard/felt was U-joint bind. You need to pull your front hubs and clean them. Do a search, it's a popular subject on the Super Duty board. I eventually dumped my automatic hubs and went with MileMarker manual hubs because they're cheaper and stronger thatn anything else available.
Old May 14, 2006 | 07:08 AM
rosco_p_coltrane
How can the hub stick in the locked position if i havent engaged four wheel drive. I didn't have any problems before the trip then afterwards the problem started, at no time was the four wheel drive engaged. Thanks for speedy response.
Old May 14, 2006 | 07:10 AM
rosco_p_coltrane
Do the MM hubs still allow for auto engagement while unlocked like the factory hubs??
Old May 14, 2006 | 01:12 PM
Jspafford's Avatar
Jspafford
No, they are either locked or free. The only way to keep the auto hubs is to go to a junkyard or Ford (ouch)
Old May 14, 2006 | 01:45 PM
Beast12's Avatar
Beast12
BUT, we do have an Excursion forum. If people post the Excursion questions in the Super Duty forum then the Excursion forum won't grow.
Thread moved to Excursion forum.
-Matt
