this may sound silly
Old Dec 7, 2015 | 12:06 PM
Hardlanding's Avatar
Hardlanding
but I am still running down a lack of power problem on my 93 (89 motor) efi 460...I checked the fuel pressure and the regulator yesterday and they check out I checked the spark it checks out I pulled the injector connection off the cylinders while it was running and 2 of them did not effect the motor...
I am going to replace the injectors, is there any tips or tricks to get them out I have a donor that seems to keep messing them up when I pulled them...
Old Dec 7, 2015 | 12:07 PM
Hardlanding
it has a slight miss and just lacks low end power...no codes are being thrown
Old Dec 7, 2015 | 01:36 PM
jas88's Avatar
jas88
You just remove the fuel rail and then pull the injectors out. You should get new O-rings and lube them with silicone before pushing the injector back into the hole.
Old Dec 7, 2015 | 08:51 PM
jaagen's Avatar
jaagen
Did you check for power at those injector connectors to double check that it's the injector? Just a thought.
Old Dec 8, 2015 | 08:23 AM
Hardlanding
Yeah got power at the injectors and also when I shut the key off the fuel pressure drops fast...like right now
Old Dec 8, 2015 | 09:25 AM
Grems4ever's Avatar
Grems4ever
That would be consistent with leaky injectors...
Old Dec 8, 2015 | 10:12 AM
Hardlanding
I hope this cures the problem because I am at my wits end with this truck
Old Dec 8, 2015 | 10:14 AM
Grems4ever's Avatar
Grems4ever
Might want to check the fuel pressure regulator as well while you have the rail apart.
Old Dec 8, 2015 | 10:19 AM
Hardlanding
it is working, however I am going to change it because it will be apart and I have a new one already
Old Dec 8, 2015 | 10:20 AM
Grems4ever's Avatar
Grems4ever
Good plan.
dp1181
Jul 31, 2017 09:10 PM
kefrko
1983 - 2012 Ranger & B-Series
Apr 5, 2016 10:31 AM
BigZ97
Dec 17, 2014 07:37 AM
coloradotoy
Dec 4, 2009 07:16 PM
lmnr0026
17
May 20, 2009 11:53 PM
