MAP sensor
Old Jan 14, 2004 | 06:48 PM
88grandmarquis's Avatar
88grandmarquis
MAP sensor
'86 F-150 EFI 302
Where is the MAP sensor located on the engine? Stupid question #2: What is the purpose of the MAP sensor?
I'd have searched, but it's not working for me.
Old Jan 15, 2004 | 12:01 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
It should be located on the left side of the engine compartment (forward looking aft.) Just back from the battery and above the vacuum cannister.
MAP = Manifold Absolute Pressure
BMAP = Barometric Manifold Absolute Pressure
A MAP sensor tells the computer what the manifold vacuum is for making fuel/air ratio and spark advance calculations.
The BMAP sensor gives the computer the atmospheric pressure along with manifold vacuum. It allows the computer to calculate the pressure differential for making fuel/air ratio and spark advance calculations. It will compensate for altitude variation and when used with an Air Temperature Sensor, allows the computer to make air density calculations.
