Hei gm ignition will this change my timming and what should it be, ive read 10 degree but also 6 degree this a straight 6 with a feedback to nonfeedback
The HEI unit will not adjust your timing whatsoever. It is merely the triggering unit and power supply for the primary side of your coil. The engine timing will still be controlled by your distributor and the spark will still come from your coil.
On many years engines the factory ignition initial timing spec is 6 degrees, but some folks have tried bumping it up to 10 or so. That only takes a twist of the distributor.
After I gave DUI (performancedistributors.com) my engine/vehicle specs and they created a custom tuned HEI for my engine, they told me that they designed it to be set at 12° base timing.
However, that's how they designed it, which means the rest of the timing (mechanical advance, vacuum advance), took that into consideration.
