A month or so ago my truck did the same thing more or less. At first I thought the same thing, tires and whatnot. Happened to look at the inner part of the rears and saw a big greasy mess on the pass side. The diff, fluid ruined my brake shoes on that side. I would check the bearings out, don't take long to do, and if you catch it before it turns into a slimy mess it will save you the price of a brake job. Do both sides while you have the punkin open. A weird thing with mine was I had the 9.75? diff but the bearings were for an 8.8. Go figure. OReallys has a puller you can rent.
Tried the tire swap with no change. Had it up on the lift again with one of the mechanics I've used. With a simple pointer attached to the frame, held near the driveshaft, the truck running and in gear, he observed a wobble in the shaft itself. It got worse with increased rpm(s). His conclusion, either some damage or a twist in the shaft. Called a driveshaft shop, they said they would make a a diagnosis when I could bring it in.
Ball joints were replaced some time back. They simply wore themselves out as Ford made no provisions for them to be greased, same as so many other suspension items. No abnormal tire wear has been noticed. Still trying to find a driveline shop that doesn't tell me the same thing: no appointments; leave it and we'll get to it when we get to it; maybe out in a day, maybe not.
remember, if you are gonna do this, support the rear axle appropriately so the driveshaft angle is at "normal"
