Check your wheel bearings. I had a similar symptom when one front bearing went out in my Explorer. At certain speeds it felt much worse than other speeds.
The wheel wasn't loose but the bearing had dried out and gotten tight. Once it was replaced, it was fine.
i had a similar problem on my truck, if i remember correctly the carrier bearing was bad on the two peice drive shaft as were a couple of the ubolts that hold the drive shaft to the differencial, my truck is a 2wd so it may be different if u have 4x4.
i had a flywheel that had broke and wedged itself back on.it caused the same symptoms you are describing.drove it like that for 3 years before i pulled the motor for something else and when i put it back in the vibration was gone
Make sure your tires are balanced and that you don't have a bent rim. Bigger tires sometimes require lots of weight to balance them, depending on the tire mfr. I once had a bad shake and thought it was a tie rod or something but it ended up being a bent rim from hitting a curb real hard at a good speed. ouch!
Give this a try, I made this suggestion on another post. This truck had the same symptoms you describe. Good luck.
Park the truck on a level surface, block the front wheels real good and put the rear on some sturdy jackstands. Run the truck to the speed at which the vibration occurs, you may need to have someone else in the truck to hold it at speed, while you look underneath at the driveshaft, and see if it looks blurry. You can even try holding a stick against the driveshaft and see if it bounces off. I used this method to trace the vibration in my mothers 95 F-150. The u-joints felt tight, and we even had a shop tell us they were good. The truck had 120k on the factory joints and carrier bearing. We replaced all the joints, the carrier, and had it balanced, and then it was fine.
I think you would DEFINITELY want someone inside the truck while doing that test. If it were to vibrate off the jack stands at 50mph and had the gas pedal wedged down, you'd be in big trouble.
Hey, I had the exact same problem and I had the drivshaft balanced, and when the mechanic was doing that he noticed that my transfer case was missing 2 or 3 bolts on it and the others were loose. He tightend them up and the vibration went away. So it was either one of those, I also thought it may be the shocks but that did nothing when I replaced those. the clutch and everything related to that also didnt do anything for me.But that was just my truck, a 79 F150 manual 4X4 351 shortbed.
wow, this could be lots of things. will start working on them. I've already replaced shocks, ujoints, and had the tires balanced. would they be able to tell if the rim was bent when they balanced the tires?
hey supercab4x4, your flywheel wedged itself back on? I replaced the flywheel about two years ago. do i have to pull the tranny back to figure that out? any other way to diagnose it?
