2004 Excursion No Start
Old Dec 6, 2015 | 05:08 PM
kafreeman's Avatar
kafreeman
2004 Excursion, won't start, just turns over. Pulled the cap off the fuel filter and it's filling fast so seems to be getting fuel. FICM replaced with a unit from Ed a year ago, along with a high output alternator, tests at 49 volts at key on, 48.5 cranking.
Truck started up fine last night, went for a drive with the family through Christmas lights. It has been running very rough at start and then smooths out after a few seconds. Went to start it up today and it just turns over, never fires. Unplugged the ICP on the passenger side valve cover and no improvement.
Pulled codes and had P0269, P0672 and P0676. Looks like a couple flow plug codes an an injector contribution code.
What else can I check before pulling the valve covers?
Old Dec 6, 2015 | 05:15 PM
navistarnut's Avatar
navistarnut
Can you post ICP and IPR pressures during cranking? Doubt it's the HPOP if you have the newer engine.
Old Dec 6, 2015 | 05:29 PM
kafreeman's Avatar
kafreeman
1100 psi and 44%duty cycle. Don't see an IPR pressure on torque.
Old Dec 7, 2015 | 02:04 AM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Do you hear the injectors buzzing key on engine off?
Old Dec 7, 2015 | 08:25 AM
kafreeman's Avatar
kafreeman
Injectors buzz, everything sounds normal at key on.
Don't think I put this in the OP, but it seemed like it had a miss right before I shut it down Saturday night. Put it in reverse to back into the driveway and it felt like it was missing.
Old Dec 7, 2015 | 02:37 PM
FICMrepair.com
Former Vendor
I asked about the injector buzz to help rule out the FICM. If the injectors are buzzing and you have proper FICM voltage (and you do), I think we can safely rule at least that out for you.
-drink
Old Dec 8, 2015 | 06:07 AM
78fordman's Avatar
78fordman
Check fuel pulse width while cranking. The actual number is not important just so it goes up from 0.
Old Dec 8, 2015 | 08:06 AM
kafreeman's Avatar
kafreeman
Got it going last night.
Checked fuel pressure and it was low. Tank sounded hollow for ~1/3 tank remaining.
Put five gallons Into it, started after a couple cranks. Drove fine.
I've had this sender read low before, now it's reading high.
Old Dec 10, 2015 | 02:15 AM
FICMrepair.com
Former Vendor
I've learned not to trust the fuel gauges. I've seen some off by as much as 1/4 tank!
Glad you got it going!!
DougJ_1997PSD
Jul 16, 2017 08:50 PM
Zagato78
29
Feb 5, 2017 10:12 PM
flcracker9
Mar 3, 2013 07:13 AM
rconnor
Aug 1, 2011 01:15 PM
RedFJ
16
Oct 14, 2009 06:42 AM
