Lund Visor Mounting
Old Dec 6, 2015 | 03:36 PM
jgavac's Avatar
jgavac
Lund Visor Mounting
Hey all,
As it gets closer to winter break, I start thinking about working on my truck instead of studying finals. I was hoping to put on the Lund Visor that I have laying around while I'm home and what I'm wondering is the best way to mount it so that it's watertight. Bolts and rubber washers?
Thanks
Jameson
Old Dec 6, 2015 | 07:32 PM
Diesel_Brad's Avatar
Diesel_Brad
And use some silicone on the screws when you install them
http://www.ebay.com/itm/like/281685744745?ul_noapp=true&chn=ps&lpid=82
Old Dec 6, 2015 | 09:34 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes use lots of quality grade silicone on both sides of the stainless steel allen head bolts. Rubber washers on both sides (bolt head and nut side) and then more silicone and self locking nuts, sounds like a good idea too.
Still a great way to rust out your A pillar, drip rail area, door hinge mount area and rocker panel area if done wrong.
Old Dec 6, 2015 | 10:38 PM
HIO Silver's Avatar
HIO Silver
If I were to install a visor, I'd use Nutserts (threaded rivets), stainless steel machine screws, 3M Window Weld polyurethane sealant, non-hardening strip caulk, and UV stable rubber washers.
Old Dec 7, 2015 | 06:53 AM
Diesel_Brad
If you think the visor caused that rust, just look at this truck with NO VISOR
Old Dec 12, 2015 | 11:34 PM
jgavac's Avatar
jgavac
Thanks everyone!
Old Dec 12, 2015 | 11:44 PM
No704's Avatar
No704
++ on the rib rivnuts be sure to use a primer.
Old Dec 13, 2015 | 10:43 AM
vtpkrat2's Avatar
vtpkrat2
I've mounted a ton of these alone and find that sitting it in place on the roof,evenly spaced from side to side then taping w/masking tape temporarily is a good start.Mark the holes to be drilled with a marker through the visor holes onto the roof. Remove the visor and carefully drill the holes to the proper size that correspond to the supplied(IF supplied) self tapping screws. Put a dab of good silicone(at least the size of a nickel)) over each drilled hole and carefully set the visor over the holes and start each screw trying not to disturb the sealant.
Hio's idea of nutserts is a GOOD idea as the visor has to be removed if changing the windshield etc. (you know if a windshield gets replaced today you will get nailed with another rock next week!) The self tapping screws are generally a 1 time in and out deal & then the holes are kind of hogged out meaning new and larger holes and self tappers next time installed..Nutserts in the roof and a 1/4 or 5/16 bolts is a nice way to go if you can. Good Luck! Gary
Old Dec 13, 2015 | 05:49 PM
jgavac's Avatar
jgavac
Quick question regarding the nutserts; How do they themselves attach to the metal? Is it a press fit? Weld in?
Thanks
Old Dec 13, 2015 | 06:06 PM
AK FORD GUY's Avatar
AK FORD GUY
They are like a fancy, industrial molly anchor.
I think a coating of a good epoxy sealant to the outside of the nutsert would seal the hole real well.
Old Dec 13, 2015 | 07:49 PM
jgavac's Avatar
jgavac
Oh okay I get it now. I completely missed the part where HIO Silver said "Threaded rivet" Finals must really be getting to me
hurst1979olds
Jan 27, 2017 07:58 AM
IMASAP
Nov 23, 2015 03:07 PM
Gear Up
Oct 31, 2010 06:02 PM
9.ford.5
Paint & Bodywork
Apr 2, 2009 01:34 AM
TurboTuff
Oct 20, 2008 01:31 PM
