Engine stalling
Old Dec 5, 2015 | 08:16 PM
Cwarstler's Avatar
Cwarstler
Engine stalling
When i am driving on the hwy the engine seems to not be getting gas. When i press the accelerator nothing happens then all of a sudden it kicks in and accelerates. Then stalls again.
Any ideas what i need to adjust?
Old Dec 5, 2015 | 09:23 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
What engine do you have btw? Honestly those symptoms could be a number of things. Hesitation is sometimes the carburetor accelerator pump shot. It is a diaphragm in carburetors that gives a little extra squirt of fuel whenever the accelerator is pressed. When was the carburetor last rebuilt? More than a couple years that would be a good place to start especially if the truck sits a lot.
Old Dec 5, 2015 | 09:56 PM
Cwarstler's Avatar
Cwarstler
Its. 289 V8 with 4 barrel carb
Old Dec 5, 2015 | 10:15 PM
Tedster9's Avatar
Tedster9
Another area to focus on if fuel delivery is suspected, direct the output of the fuel pump at idle RPM into a clean container. Must be 1 pint in 30 seconds minimum.
Verify/Reset proper float level after carb rebuild, etc. Too low can cause the symptoms you describe. Those fuel pumps also had the integral fuel filter canister. Work through the beast and it will start running like a champ!
LittleBlue79
21
May 25, 2018 02:50 PM
corkel
Dec 8, 2014 05:20 PM
cajunhcm
Mar 16, 2010 06:53 AM
datchew
Dec 20, 2009 06:38 PM
PatBethea
Dec 9, 2008 11:00 PM
