Do you have the Ford 10.25" sterling rear end? If yes then this is ONE option for you. It's a tough, predictable LSD that has a proven track record both on and off road. There are other options for sure but they all have their pros and cons.
Since I have a 2wd DRW w/350K, I'm gonna re-gear to 4.10's at the same time I do the truetrac install.
Just curious, but how do you know that's the one I need? I saw a bunch of different options when I looked for axle and splines, how do you know that's the correct one? Is there something I'm missing (very likely) that narrows it down?
I am under the impression that your '02 F350 is an SRW model since you didn't call it a dually. My '01 F250 and a SRW F350 share the same model rear differential, a Ford/Sterling 10.5'' 3 pinion differential. The Eaton 915A550 Detroit Truetrac 10.25/10.5" 35 Spline Differential is the correct one for that application. If you have the DRW version with a Dana 80, there are 2 different options depending on gear ratio. Also, the installation instructions will vary somewhat. More information would be helpful.
I am under the impression that your '02 F350 is an SRW model since you didn't call it a dually. My '01 F250 and a SRW F350 share the same model rear differential, a Ford/Sterling 10.5'' 3 pinion differential. The Eaton 915A550 Detroit Truetrac 10.25/10.5" 35 Spline Differential is the correct one for that application... More information would be helpful.
Is that the only option for the SRW? If not, how can I find out? All of this information is incredibly appreciated!
Yup it's a Dually but I plan to do gears too, going to 4.10's
I would like to do the same but as mine is 4x4 it's going to be too much $ & too much work although it would be great to have a lsd up front too! There isn't much available for the front axle AFAIK. I did wonder about putting a spool up front as the only time I need 4wd is on mud or snow.
I've got 420K on my rear axle. I purchased a TruTrac and planning to install it. My rear (axle) makes little noise, that I can hear anyway. My question is, How far should I dig into this thing? Am I safe just installing new carrier bearings and races or plan on the whole thing?
Anyone have any experiences with high mileage trucks?
Do you need to spread the housing to remove & refit the diff? I seem to remember that when I did a ratio change on a Dana 60 a spreader was needed.
Originally Posted by SRBF150
A spreader is not required. The diff can be pried out easily enough and preload is achieved by tapping in the new shim packs. It's not a terribly time consuming effort but you do pay attention to getting as close to the existing backlash value you can (plus minus 2 thou) and preload.
I had to replace my inner oil seals on my front axle (Dana 60). The night before I re-installed the carrier I wrapped it in several garbage bags and put it in a cooler of ice. The next morning I installed it with no problem (including the shims). Everything went in by hand (carrier and shims) and no spreader required.
