To a person who will be leaning as they go, are there any resources you'd recommend before/during the switch?
Here's the PDF. I promised. Differential Case.pdf The special tools aren't totally necessary, but there is a lot of good info/specs in there. When I purchased the Detroit Truetrac, it came as a kit with new carrier bearings and adjustable shim packs. This made the installation process much easier since I wasn't R&I'ng the old bearings.
Here's the PDF. I promised. Attachment 129859 The special tools are totally necessary, but there is a lot of good info/specs in there. When I purchased the Detroit Truetrac, it came as a kit with new carrier bearings and adjustable shim packs. This made the installation process much easier since I wasn't R&I'ng the old bearings.
Wow! This is fantastic! Did the Truetrac come with everything you need? Obviously not the special tools, but everything else? Thanks a lot! I really appreciate it!
I purchased it from an Ebay seller several years ago. It came with the 2 new side bearings & races, shim packs (adjustable multi piece shims vs the stock thick ones), the Truetrac unit, and a cover gasket (didn't use). After some looking now, I don't see the seller or anyone else that offers the complete kit. You can, however, purchase a Carrier Bearing Install kit and the Truetrac separately. The prices are substantially higher now than when I got mine. I got the entire kit for less or about the same price as the just the differential.
Another thumbs up for the Truetrac as opposed to other LSD options- the Detroit Locker is great/strong but noisy, and air or electric lockers are expensive and obviously, need air or 'lectricity plumbed also.
The Truetrac is reliable, no clutches to wear out, no switches to engage; just seamless! Works when you need it and you don't have to think about it.
Are you sure you have an open diff? I have an 02 F250 that is not an FX4 and it has the limited rear. Check the metal tags on your diff and it should tell you what you actually have back there.
x2 for that. Mine has the LSD but it is very old and feels like an open diff. It works great in the dirt but not so much on the pavement (even when it's wet).
I just checked and unfortunately I don't have the LSD in the back :/
What type of information do I need to make sure I get the right LSD? I'm looking at the Truetrac and want to purchase in the near future.
Just curious, but how do you know that's the one I need? I saw a bunch of different options when I looked for axle and splines, how do you know that's the correct one? Is there something I'm missing (very likely) that narrows it down?
