After many hours of ohming wires and checking circuits I have concluded I need a PCM. My question is: Which of the numbers on the PCM's need to match? Mine are as follows:
Only insofar as the PATS has the ability to trigger the ECM into not starting. There is no PATS key code information stored in the ECM, that information is stored in the PATS module.
My information said it's mounted under the RH portion of the dash behind the passenger airbag while the ECM is mounted in the engine compartment.
Now you've got me second guessing myself.
Also curious as to whether anything has to be done about the PATS when swapping a PCM.
All advice greatly appreciated
Ok need part number on Motorola and use ford's part number also hope you know you have to program it I bought a scanner I can use on laptop with Forscan. org you can change settings actually I've programmed my injectors etc make sure it is bad
