Oil pump shaft
Old Aug 6, 2003 | 08:44 PM
90f150moneypit's Avatar
90f150moneypit
Oil pump shaft
Just put the oil pump on the 302. But I have about 1/16" to 1/8" of play up and down with the pump shaft.
Is this normal or should the shaft be tight up and down after the pump is torqued down?
Is it possible the end of the shaft has worn down causing the slop, even if it looked fine?
This is the original shaft with a new pump. I got tired of waiting for the back ordered shaft to arrive so I thought I would slap this one back in. This MAY be the "knock/rattle" I was having because I could hear it through the distributor. That's why I replaced the distributor.
Has anyone installed their pump and noticed this as well?
I'll wait to slap the pan on until I find out for sure.
Thanks!
Old Aug 6, 2003 | 10:15 PM
FTE Herman's Avatar
FTE Herman
Oil pump shaft
That play is just fine.
Old Aug 7, 2003 | 02:17 AM
90f150moneypit
Oil pump shaft
Okey Dokey, I'll seal er up in the morning.
Thanks!
Old Aug 7, 2003 | 07:18 AM
TorqueKing's Avatar
TorqueKing
Oil pump shaft
Where'd you order the shaft from? I've ordered parts from Summit late on a friday, and they show up to my house saturday at noon. Of course overnight shipping runs about $12 more.
Old Aug 7, 2003 | 01:39 PM
90f150moneypit
Oil pump shaft
I see Summit has two FRPP shafts. One is not for EEC-IV and the other is. Does anyone know what the difference is? Is it possible my old is the wrong one?
Old Aug 12, 2003 | 10:41 PM
pinellas50's Avatar
pinellas50
Oil pump shaft
I just did this install. There is supposedly a difference between the two shafts but I don't know exactly what it is. Call a tech line or a speed shop. It might be wise to spend an extra couple of bucks to get a hardened pump shaft. There are several different companies selling them. At $16 it's cheap insurance.
Old Aug 12, 2003 | 10:49 PM
90f150moneypit
Oil pump shaft
I should get the new FRPP shaft by Thursday. I just recieved my pump primer. The FRPP shaft is a stronger one than stock, it's made of Chromemoly Steel. I ordered it from Summit for $19.
Thanks!
Bronco351W
Apr 9, 2021 07:23 PM
annaleigh
Apr 23, 2015 03:14 PM
BigDoug
Nov 22, 2014 04:35 PM
OrangeJuice
Jun 5, 2009 02:21 PM
imlowr2
Jul 16, 2004 04:15 PM
