7.3 hiccups
Old Dec 3, 2015 | 03:59 AM
toadx8u's Avatar
toadx8u
7.3 hiccups
So my 7.3 has really never had any issues but a few weeks ago it left me sitting with a no start situation and had to have it towed... Before the tow came I replaced the CPS cause I keep a spare in the truck and I wasn't seeing any RPM when cranking but it didn't fix anything... So I get the truck towed home and it just sits a few days... I walk out one day just for ****s and giggles to ur and start it and it starts but only after some excessive cranking.... So i take the truck down the road... It's idling fine no issues but the min I pull out on the road it starts burping and farting and herking and jerking... The injectors are clacking and banging and the truck is bucking like a wild horse... So I run around and come back home... No CEL no codes nothing.... It also seems like this is happening more under partial throttle vs full throttle I took a couple videos I'll try to load them here in a little bit
Old Dec 3, 2015 | 07:16 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
What is your fuel level reading, maybe a Hutch mod is required? Sounds like a fuel delivery/supply problem to me. Have you checked the fuel filter or pressure from the pump?
Old Dec 3, 2015 | 08:46 AM
HKusp's Avatar
HKusp
Cosign on Sous' thinking. Sounds like text book symptoms that your foot may have fallen off of the pick-up in the fuel tank, and or the screens are clogged.
bruno2
Jul 2, 2015 04:42 PM
JNG6
22
Dec 19, 2013 05:33 AM
Bigal700
Feb 26, 2013 06:58 PM
15 and 92 Dad
Jan 29, 2008 05:04 AM
