7.3 died
Old Feb 19, 2013 | 09:42 AM
Bigal700's Avatar
Bigal700
7.3 died
I have a f250 with a 7.3 idi was driving it and like all the sudden id like got power so i let off the gas and went like a 1/2 mile and it died like it ran out of fuel in my opinion the injector pump took a crap but im looking for advice it use to smoke blue out the pipes and wouldent clear up
Old Feb 19, 2013 | 10:50 AM
fordhorse's Avatar
fordhorse
Was the truck around a 1/4 tank, will it start back up when it cools down?
Old Feb 19, 2013 | 11:53 AM
tjc transport's Avatar
tjc transport
i ain't rite
try putting fuel in it first, it may have run out of fuel.
Old Feb 19, 2013 | 03:19 PM
Bigal700's Avatar
Bigal700
I dident run it out of fuel trying fuel filter tonight
Old Feb 19, 2013 | 03:56 PM
tjc transport
i ain't rite
i did not mean you intentionally ran out of fuel. these trucks are known for breaking the pickup in the fuel tank between 1/4 and 1/2 tank.
you can have 1/2 tank of fuel in it and still "run out of fuel"
Old Feb 19, 2013 | 10:15 PM
Bigal700's Avatar
Bigal700
Oh ok ill pick some fuel up and try that i thinks it around half a tank but my gauge dont work so i go by miles
Old Feb 20, 2013 | 09:07 AM
tjc transport
i ain't rite
on my 88, the front will "run out" or start sucking air at a little under 1/2, the rear a little over 1/8 on the gauge.
so i just make sure i keep the front over 1/2 and the rear over 1/4
Old Feb 21, 2013 | 09:52 AM
Bigal700's Avatar
Bigal700
my rear tank has a hole but i need to reprime it then ill try to start it when i turn the key and let the glow plugs cycle then i can hear the injector pump kicking in
Old Feb 21, 2013 | 09:58 AM
tjc transport
i ain't rite
pull the fuel filter and fill it up. that makes a world of difference.
Old Feb 26, 2013 | 12:19 PM
Bigal700's Avatar
Bigal700
I put fuel in it and i emptied the filter and the filter fills up and the i cracked an injector and nothing comes out of injector so is there a way the injector pump air locked or is it just plan shot?
Old Feb 26, 2013 | 06:58 PM
tjc transport
i ain't rite
when you turn the key to run position, do you hear a click from the injector pump? the fuel shut off valve is the rear of the two wires. it should have 12 volts when the key is on.
if no power, it is an electrical. if there is power, try unplugging the wire and listen for the valve working if no noise, the fuel shut off in the pump is bad.
the fSS is generally not a owner serviceable item, if the cover is not put on just the right way, you will get a full throttle runaway condition that could blow the engine.
do you know how many miles are on the injector pump? pump and injectors are usually a replace between 100 and 150 thousand miles recommendation.
i got 60K out of the first pump, 160 from the second, 140 from the third, and have 140 on this one. the current pump is getting very tired and really should be changed again, but i just haven't gotten around to it.
JSpivey779
May 4, 2018 02:02 AM
EL1XER
Dec 25, 2013 05:43 AM
BigTodd
Jun 29, 2011 11:48 AM
skipkelly
17
Apr 11, 2011 12:32 PM
DVDavid
General Diesel Discussion
Jun 27, 2010 10:15 PM
