Power Steering Conversion on 1973:
Old Dec 1, 2015 | 01:58 PM
leonharu's Avatar
leonharu
I have a 2WD, 1973 F-100,360 engine with automatic transmission and thinking about converting manual steering to power.How difficult is it to change over.I have already been told that the steering column will have to be changed!I am not sure about taking a totally original nice truck and start doing modifications???
Old Dec 1, 2015 | 02:28 PM
HIO Silver's Avatar
HIO Silver
Confirm whether it's 2WD or 4WD.
I suggest editing your signature to include your vehicle configuration without us having to ask... it's just more efficient that way.
Refer to my signature below as an example....
Old Dec 1, 2015 | 07:08 PM
mikeo0o0o0's Avatar
mikeo0o0o0
On the 2WD it's basically a bolt on operation.
You're correct, you'll need to change the column. The p/s box is long than the manual, so the p/s column is shorter.
What you'll need is the column, p/s box, pitman arm, power steering pump, engine brackets and the correct pulley to drive the pump.
dusterbd13
May 18, 2015 01:43 PM
tstewart78
Mar 3, 2014 02:16 PM
ccsettles
Apr 24, 2007 10:06 AM
bucks77ford
20
Jan 7, 2007 09:58 PM
Rocking M
Jan 5, 2004 09:55 AM
