power steering conversion questions
Old May 18, 2015 | 11:01 AM
dusterbd13's Avatar
dusterbd13
so, I finally found a power steering pump and bracket setup for my nieces 77s f150 2wd. 6 cyl, 3 on the tree if that matters.
now I need a box.
what years can I use for a donor?
other than box, pump, lines, brackets, and belt, any changes? steering column the same? pitman arm? rag joint?
thanks. I looked through the faq's, and also googled, but didn't really find anything.
thanks for any help you can throw my way. pretty much, I need to know what all I need to know to make this a simple and quick swap.
Old May 18, 2015 | 01:43 PM
Canus's Avatar
Canus
When I converted my 74 I used the box and column from a 76. The column for power steering is shorter than the manual column. I would think any 73-79 box and column would work. Recomend getting the box rebuilt by red head.
leonharu
Dec 1, 2015 07:08 PM
bwb-cc
Dec 19, 2010 01:52 PM
TAMA1965
18
Oct 16, 2007 09:12 AM
williamwilliam
15
Jul 21, 2003 09:18 PM
