Facet Duralift conversion problems...
Old Dec 2, 2015 | 09:37 PM
Pkupman82's Avatar
Pkupman82
Originally Posted by Pkupman82
The truck has a half a tank of fuel. It used to have dual tanks, I deleted the front tank and bypassed the selector valve. I bought the pre-made flared steel lines (they come double flared) to replace the rotted out originals. As for going overkill on clamps, yeah you got me there. But I use them in places where I don't have the barbed fittings or flared ends. I hate leaks! Anyway the compression fittings seem to have done the trick. No more bubbles in the fuel bowl, and the engine purrs like a kitten. I was having trouble starting it even after sitting for a few minutes, that seems to be cleared up. The real test will be when I try a cold start after work tomorrow. Thanks for all the help guys, it is very much appreciated!
Well the moment of truth came this evening. I did another cold start with the new fuel pump. It is better than before, but it still took a lot of cranking before she fired up. I'm suspecting it's loosing prime. The only other thing I can think of is air intrusion on the return line under the truck. I recently did the return lines, o-rings, and injector caps. There are no visible fuel leaks that I can find. Is it possible that IP timing could cause this?
Old Dec 2, 2015 | 10:14 PM
The_Josh_Bear's Avatar
The_Josh_Bear
IP timing won't cause random cold-start issues.
It WILL make it easier/harder to start, but we are talking big chunks of timing, like 5-8* and beyond. (My pump used to be AMAZINGLY retarded, supposed to be at 8*BTDC I think I was at 2*ATDC once I finally got a timing meter on it. Anyway, started like a dream super retarded like that.)
I know you've gone over this already but you may have to re-evaluate every connection from tank to epump, then each one from e pump to fuel filter header, and everything coming off the header too.
Do you still have the stock air-return line from your fuel header? It's the little line that goes from filter header to the #1 cyl if you still have it. Has a little rubber check-valve in it which dies and then becomes an air-intrusion magnet. Either put a real check valve in place of it or plug it all together. Just note that if you plug it and lose your prime you'll have to find a way to fill up the fuel filter before re-priming the system(not hard just don't forget! I know the hard way...)
Oh and air is thinner than fuel so you can often have a place air will leak into a hose/seal, but fuel won't leak out, which makes looking for air intrusion points quite tough.
Something thing you can do to verify that it's air instead of glowplug system is to temporarily install a clear hose between the IP outlet and the return line. Then before you run the engine just pop the hood and turn on the pump with power to the IP, this opens the check valve in the back of the IP and lets air out faster. It's pretty easy to tell at that point, if air comes out you have air intrusion!
Old Dec 3, 2015 | 04:43 PM
Pkupman82's Avatar
Pkupman82
It wouldn't surprise me if the check valve in the return line is bad. I think I'll try deleting the line see if that helps.
Old Dec 3, 2015 | 08:25 PM
Macrobb's Avatar
Macrobb
I have mine blocked off and I haven't had to fill the filter when I run it out of fuel... I floor the throttle so the IP actually pumps fuel/air through it, and that seems to work.
Also, do yourself a favor and get a $5 squeeze-bulb primer and put it in the incoming line just before the filter head. It has two check-valves in it and works amazingly well to keep things from draining down.
As a plus, you can always squeeze it to see if there's air in the system at that point, or prime the system manually if things go wrong.
Old Dec 4, 2015 | 06:39 AM
tjc transport's Avatar
tjc transport
i ain't rite
no need for the squeeze bulb with the facet in the line, there are one way valves in the facet pump.
i need injectors, o-rings, and caps on the 88. since i put the facet pump on i have not had one lick of air intrusion problems.
Old Dec 4, 2015 | 11:24 AM
The_Josh_Bear
X2 I had a good check valve pre-filter before the facet install but took it out cause the facet has one. Works great.
Macrobb I agree that you can fill the fuel filter using the key on and throttle, but if you forget to do that first(like I have) then you just make more air go into the IP and waste time. Just don't forget!
Jesse James DeMoor
Oct 11, 2018 07:32 AM
USMC 5811
18
Feb 22, 2011 03:31 PM
BoyHasAFord
20
Jun 30, 2010 10:09 AM
midapo
Oct 30, 2008 07:02 PM
BoostLover
Nov 28, 2003 11:59 PM
