drum to disc conversion
Old Nov 30, 2015 | 02:19 PM
filthy6's Avatar
filthy6
Good afternoon...Axeracer has convinced me that the stock front axle will be adequate for my needs and skills. I am going to upgrade to front disc brakes and a duel master cylinder....undecided on power brakes or not. What set up are you guys using and what company did you purchase from....are you satisfied? I know there is one company that is " NO BUENO" but I can't remember which one. Want to do this just once. Thanks
Old Nov 30, 2015 | 02:59 PM
yamagrant's Avatar
yamagrant
I've got the Speedway front disc conversion, and a power booster/master cyl with proportioning valve from POL. Good luck.
Old Nov 30, 2015 | 03:20 PM
Schuyles's Avatar
Schuyles
I used the speedway front disc brake conversion kit (about $279) and CPP under floor booster/master. I'm not driving my truck yet, but it all went together nicely. I did opt for the remote reservoir kit from CPP and bought a remote reservoir on ebay - but I did it more for fun than necessity.
Old Nov 30, 2015 | 03:25 PM
filthy6's Avatar
filthy6
I will check out Speedway. I should have mentioned the PO changed the pedal configuration so I will have the duel master cylinder on the firewall.
Old Nov 30, 2015 | 03:44 PM
Schuyles's Avatar
Schuyles
The speedway kit will be the way to go if you don't want to source all the parts by yourself (seems that breaking down the parts individually isn't a whole lot cheaper). You can buy just the brackets and bushing for about $100, but I would go for the whole kit if it doesn't break the bank. Now is the time to go for it as I think it's free shipping for cyber Monday. I bought mine when they had a $7.99 flat shipping rate going on.
I guess I'm assuming you have a '53-'56 F100 and that you want to keep 5x5.5" bolt pattern. You might want to order new kingpins from speedway while you're at it.
Full Kit:
1948-1956 Ford Half Ton Deluxe Disc Brake Kit, 5 x 5-1/2 Inch - Free Shipping @ Speedway Motors
Smaller Kit:
Basic Disc Brake Kit, 1948-56 Ford Half-Ton, 5 on 5-1/2 Inch - Free Shipping @ Speedway Motors
PIGGYONAHOG
Apr 28, 2018 10:16 AM
Fyrhosr
22
Apr 25, 2016 05:18 PM
jerryst
Oct 5, 2011 10:29 PM
shermy2296
Apr 11, 2006 09:03 PM
jowilker
Apr 4, 2002 11:47 PM
