drum to disc conversion ???
Old Mar 30, 2002 | 07:08 AM
jowilker's Avatar
jowilker
Old Apr 4, 2002 | 05:00 PM
badboyina67's Avatar
badboyina67
Do I have to put a power booster on to run the discs??? I just put a new manual master cylinder on and don't want the big power booster under the hood. Thanks!!!
Ken
Old Apr 4, 2002 | 05:28 PM
TomThrall's Avatar
TomThrall
I don't suppose you are required to have power brakes, but I thought the main reason for installing discs was to improve stopping power, and I know from experience that the booster makes these brakes work great!!
Unless you have done this conversion, I cannot fully make people understand how well these brakes work. Take 1 70 Ford, install discs all the way around, install a proportioning valve, then a brake booster, and you will have better stopping ability than 99% of the vehicles on the road, including the new ones.
I advise getting the booster...heheh
Old Apr 4, 2002 | 05:30 PM
red450ih's Avatar
red450ih
Is the master cyl different on trucks with front discs? about to start same conversion on a 69 with power brakes and drums all around.
Thanks,
Keith
Old Apr 4, 2002 | 05:49 PM
BB's Avatar
BB
Yep, different master. The bore size is larger.
Old Apr 4, 2002 | 09:25 PM
Mil1ion's Avatar
Mil1ion
Further to TOM's post.
Get yourself the booster for the F-350.
With this you will be able to stop on a dime and give 9 cents change!
[i][font color=blue]Dennis[/font][i]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[i][font color=green]
http://www.clubfte.com/users/mil1ion/Mil1ion.html [/font][i]
[font color =green] Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
78-Buick LeSabre 403 4V
84 Volvo DL Wagon [/font]
Old Apr 4, 2002 | 09:52 PM
sullyda1's Avatar
sullyda1
I agree the power booster is a must. I found that the 1" diameter master cylinder works best with front single caliper discs and rear drums. If you go to a larger diameter, the pedal tends to be hard. I originally had a proportioning valve but later removed it and installed the Wilwood adjustable with only two turns for the best stopping. My truck is a 67 F100 which has smaller rear shoes than later 68-72. I installed the front disc setup from 1977 F150.
Everything bolted in. I did make a bracket and add about 2" to the steel lines at the front rubber hose connection for better clearance.
Also, I had to shorten the rod from the back of the booster to the brake pedal by cutting out a section, then threading the rod and installing a conector bolt.
Old Apr 4, 2002 | 11:47 PM
BB's Avatar
BB
I wouldn't recommend using the 1" master with F250 dual piston calipers.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
