1990 idi Fuel System Refresh
Old Nov 29, 2015 | 08:56 AM
fhafer's Avatar
fhafer
Guess what day it is?!
Old Nov 29, 2015 | 08:57 AM
fhafer's Avatar
fhafer
Lesson number one: The time spent trying to dig the hardline rubber seals (aka "olives") is better spent getting your torch and burning them out.
Old Nov 29, 2015 | 10:14 AM
IDIoit's Avatar
IDIoit
lesson # 1B)
delete olives and run AN feed line
tube fittings from lift pump to filter (if youre running stock LP)
incorporate return line from IP to the back return line manifold through injectors.
never play with olives again!
Old Nov 29, 2015 | 10:48 AM
fhafer's Avatar
fhafer
Injection pump, injectors, return lines, and first valve cover removed. It took my 15 year old son and I 2 1/2 hours. Time for lunch!
Old Nov 29, 2015 | 12:21 PM
fhafer's Avatar
fhafer
Left side; #2 at the top,#4.#6,#8 at the bottom. I put these in four years ago...they might have 2K miles at most. I don't drive it much.
Old Nov 29, 2015 | 12:28 PM
fhafer's Avatar
fhafer
Right side; #1 at the top,#3.#5,#7 at the bottom. again, not many miles since I put the BB series injectors in around 2011. 2K maybe?
Old Nov 29, 2015 | 12:31 PM
fhafer's Avatar
fhafer
Might have a bad head gasket...looks like a jacket water leak on #6 & #8 Rut Row Raggy!
Old Nov 29, 2015 | 12:33 PM
fhafer's Avatar
fhafer
New valve cover gaskets in...time for the new injectors to go in.
Old Nov 29, 2015 | 02:44 PM
fhafer's Avatar
fhafer
Done...truck runs pretty well. We'll giver her a shakedown tomorrow; it's starting to rain and it got cold. 6 1/2 hours to remove & reinstall the ip, injectors, olives, and valve cover gaskets. I'll run it for a few hours and pull #6 and #8 injectors to see what's up.
Old Nov 29, 2015 | 07:01 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Ive seen lots come out looking that way. Just moisture, those two may of gotten some water past the big threads of the injector at one point, wouldnt worry about it too awful much.
Old Nov 29, 2015 | 09:23 PM
Macrobb's Avatar
Macrobb
Yup, this is what happens. Moisture/water ends up working it's way through the threads and creating rust.
I coat mine with a nice coating of wheel bearing grease prior to install to prevent such rust... seems to work.
Old Nov 30, 2015 | 04:50 AM
fhafer's Avatar
fhafer
Thank you for the replies guys! I had the hood up for two days charging/replacing the batteries before I did the fuel system repairs...and it poured down rain one day. I replaced my hood cowl seal this spring after snow plow season, so I know it didn't come in that way.
Thanks again for the sage advice!
Cheers,
Weedhopper
Old Nov 30, 2015 | 11:08 AM
fhafer's Avatar
fhafer
So, not wanting to goon up my engine after yesterdays work, I called around to get my truck timing set. The cheapest quote I got was $285.00 (he said it takes three hours!). I already have a good timing light; OTC 3367. For that money, I can buy the Ferret Industries pulse meter V765-01; Ferret Instruments V765-01 Injector Tester - Fuel System Tools
Besides a turnbuckle for setting the RPM at 2,000...is there anything else I need?
Thanks,
Weedhopper
Old Nov 30, 2015 | 12:20 PM
kla94's Avatar
kla94
The ferret is a good investment if you plan to keep your truck. There's a youtube video of AKAMcGyver using his meter.https://youtu.be/4GtFvIhDXzk
Pretty sure this is it.
Old Nov 30, 2015 | 12:32 PM
fhafer's Avatar
fhafer
$200.00 seems cheap compared to damaging my engine because of bad ip timing. I'll check out the video...thanks heaps!
