Sponsored by: Real Truck
Power window trouble
Old Nov 27, 2015 | 09:48 PM
2213danny's Avatar
2213danny
My power window on the driver side works. But tops at 3/4 way down. Ivan repulse the button several times to get it all the way down and occasionally it will work on the auto down. But rarely.
Any idea what's wrong. Probably switch. .. Thanks for the help
DAN
Old Nov 28, 2015 | 05:32 PM
2213danny's Avatar
2213danny
It stops 3/4 way down. I can repeat pushing the button many times and it will go all the way down. Is it the switch. Thx dan
Old Nov 28, 2015 | 06:29 PM
Chuck's First Ford's Avatar
Chuck's First Ford
dry tracks... dry bushings..... something bent/loose.
weak motor,
it would also be NICE.. if you would state what YEAR/MODEL/number of doors...
I guess its a Ford Truck????? but I can NOT see it..
Old Nov 28, 2015 | 06:35 PM
2213danny's Avatar
2213danny
Power windows
Sorry but it's 2000 f250 super duty 40,000 miles. Extended cab 4 door 2 front doors have power windows 2 back doors just have the wing windows
Old Nov 28, 2015 | 10:34 PM
wrvond's Avatar
wrvond
Because they are often exposed to rain, the switches in the door have a tendancy to corrode and stop working correctly. I would pull the panel and check the insides of the offending switch, as well as it's connector. A shot of deoxit may be all it takes to return your switch to full service.
Old Dec 18, 2015 | 03:58 PM
Jeff Watts's Avatar
Jeff Watts
I'm having the same issue on a 2011 F-250. Worse when cold. I can help it by pushing on it. When it's warm or hot out, it works fine.
Old Dec 19, 2015 | 01:50 PM
wrvond's Avatar
wrvond
It doesn't take a lot of pressure to stop one of these auto windows in their tracks. I'd remove the door panel and clean and lube the guides and pivot points.
Old Dec 21, 2015 | 12:06 PM
FordService's Avatar
FordService
Official Ford Rep
Have you mentioned this window issue to your dealer, Jeff? If not, I'd recommend that as a next step. What's the truck's current mileage?
Crystal
Old Dec 21, 2015 | 06:17 PM
Jeff Watts's Avatar
Jeff Watts
Mileage is 107k. Dealer won't "do" anything. I can put it in there, and let their "mechanics" work on it. They totally suck. I don't trust them at all.
gabes
May 8, 2015 09:12 AM
mike L
Sep 23, 2013 09:42 AM
gad4wd
2004 - 2008 F150
Feb 18, 2008 10:33 AM
Dutch123
1978 - 1996 Big Bronco
Nov 22, 2004 09:32 PM
Thumper47
1983 - 2012 Ranger & B-Series
13
Oct 5, 2003 04:17 PM
