4x2 both rear wheels spin?
Old Sep 25, 2004 | 08:22 PM
blk04's Avatar
blk04
Okay, this is probably a stupid question but here it goes. If you have a non-4x4 are both rear wheels suppose to spin? This is what I assumed but I noticed yesterday that when I was reversing over some grass I came to a wet spot and the right wheel started to spin. I couldn't go anymore in reverse so I put into drive and all was fine. Can someone clarify?
Old Sep 25, 2004 | 08:30 PM
B_7700_4X4's Avatar
B_7700_4X4
Unless you have a limited slip differential or install a locker, a normal open differential will transmit all the torque to the wheel that has the least resistance, which, in your case was the wheel in the wet grass. In short, yes, this is normal.
Old Sep 25, 2004 | 08:31 PM
79REK's Avatar
79REK
In your situtaiton, both rear wheels would spin only if you have the limited slip rear axle option so your truck must not have this option. A limited slip rear axle has clutch packs that transfer power to the wheel that is not spinning. The standard rear axle is called an open differential.
Old Sep 25, 2004 | 09:20 PM
blk04's Avatar
blk04
Thanks for clearing that up.
torquemeister
Dec 12, 2013 12:16 PM
scottm1
Jun 9, 2013 01:05 PM
chad_mcvay
2004 - 2008 F150
Oct 15, 2012 03:08 PM
triassic
Offroad & 4x4
19
Dec 12, 2009 12:21 AM
tropheytruck
6.4L Power Stroke Diesel
Dec 17, 2007 08:07 PM
