Please help me to understand...our trucks (2019 F350 6.2 in case it matters) have AdvanceTrac and open differentials...we have the option of an electronic locking rear axle...so, if we were to be on the slipperiest of slippery surfaces, even throw in a slight ascending grade ahead to make the sutuation worse, and do not have the rear locking axle, we are not going far, right?... one wheel per axle is going to spin with the other sitting stationary, correct? ( If we had traction control tge spinning wheel would slow down but the opposite wheel would remain stationary...am I right? ) Please advise, thanks.
2019 350 Diesel drw. Was on a steep parking lot here at the ski resort. Had to switch to 4h (not 4l) to get out of parking lot. Haven't had to use 4L for anything yet, although I did turn it on 4L and drive it about .1 miles just to make sure it worked lol. My first truck so I'm still learning the ins and outs, working my way through the manual.
An open diff can at times spin both wheels however it’s not very often. Open diffs usually spin the wheel
with the least amount of grip. Traction control does help a little bit but it won’t be as effective as a locker or limited slip. That being said in icey conditions I prefer an open dif 4wd system so i don’t lose the rear of the truck when the limited slip decides to lock up while making a turn.
Thanks, DeputyDiesel, my point is that we cannot get a limited slip (or traction control, I believe, AdvanceTrac is for stability only), we get open differentials with the added option of a locking rear...the locking rear is great when needed, but cannot be used except within limited speeds, the other 99+% of the time we have nothing but opposite diagonal single drive wheels...
ATC Crazy - where does that occur? where does the 'splice' occur, at the rear end, under the dash, at the control ****, under the hood...
It's been too cold for me to tear into it, so I haven't actually done it yet You can either tie into the wire behind the **** on the dash, find it under the hood on the firewall, or run it all the way back to the axle (or however far you can trace it back). All you need to do is supply the locker's + wire with 12V power.
I got into some goo one time, I mean it was like grease almost. I had lockers F/R and I could not get out even with my BFG KM2 off road 37x12:50 tires, all it would do is go around in a slow circle. This was on some property that had a slow seep spring and the area was more or less round and about 4 ft across. It had been there for years. After sitting there trying to get out for 40 min or so for some reason I decided to turn off my lockers and see what would happen. I drove out with no problem.
WHY?
The answer was simple and I knew it as soon as I got out of the goo.
Lockers: Both wheels locked f/r and I just spun going no where.
Open axles: What was happening was that my tires did not all just spin, but rather only one did on each axle at a time. But it was a near constant shifting of driving wheels and like you can often (in 4x4) use your steering wheel to go back and forth with your front wheels shifting traction and moving mud or whatever.
NOTE: This was a highly unusual and rare circumstance and in my over 50 years of off roading across the world this was the ONLY time it ever happened to me.
17 Oaks - you said: my tires did not all just spin, but rather only one did on each axle at a time you are saying that one wheel, always the same wheel, spun per axle, right, or are you saying that the wheels on an axle alternated spinning one at a time ?
In that unique situation with any level of traction shifting constantly it was affecting the CoT, coefficient of traction (friction) the result was a constant and shifting dance and it was that which got me out rather than all wheels being locked and driving at the same time.
The first car I ever owned had a limited slip and they all have had LS or lockers since.
