I thought I had original bed wood here but, it can't be. Bruce Horkey's crossmember kit only has 6 crossmembers. They look like these but there are too many here. Is this just a beefed up repair from a previous owner?
Six is correct. Does the Horkey kit include the metal insert strips that go at the ends of the two smaller middle cross members? I'll be needing to order the kit myself down the road. Stu
Another kit question. Does it include the rubber seal/tubing that runs along the bed sides? The bed in my second above pic is untouched and still has that seal. Stu
Man, yours is truly original. No, I think it is just 6 wood crossmembers and the steel plates. No hardware or seals. $335.00. Says 60 lbs. Not sure what shipping would be.
Abe, thanks for the reply. Mine will be steel soon. Wood just drys up, shrinks and splits really bad in this climate.
I can get the steel for about $100. Not original but, should really secure the bed to the frame well and not get loose and wobbly. If anybody down the road wanted original, they can unbolt it and chuck it for the wood. It'll be after I'm gone.
My 56 has metal cross members ,8' box. Iam going to have shop with a big break make new ones for me. Mine have sheet of chipboard in it when in I got it but isaw no sign of wood cross members.
Scott,
Did you go with the steel cross members?
If so, what did you use?
I did go with steel. I posted the details and images here. I used 2 1/2" square tube x .120 wall.
It needs to be 2 1/2" tall and it was all I could find locally. I later found that there is another size available I would have used instead if it was available at the time. It is 2 1/2" x 1 1/2" x .083.
MY original wood was 2 1/2" tall by 2" wide. It had been replaced so I don't know what Ford put in.
The front cross member needs to be wider and attach to the front bed panel.
