General Automotive Discussion
Tranny question
Old Nov 24, 2015 | 07:56 PM
Jason Rzechula's Avatar
Jason Rzechula
Tranny question
Can I make a 93 4x4 tranny work for my 2 wheel drive 95 maybe swap some parts got a deal on one and I lost reverse and 5 the gear in mine need cheap fix
Old Nov 24, 2015 | 09:24 PM
85e150's Avatar
85e150
You can but you have to take it all apart and put the tail shaft and output from the 4x4 trans in the 4x2 trans.
What transmission do you have and have you pulled to top cover to see if your shift forks and stick are worn
Old Nov 24, 2015 | 10:38 PM
Jason Rzechula
It is the Mazda tranny ,I replaced the shift forks 4 months ago for 1-2 and 3-4 didn't even think to check 5-r cuz they arnt with the others,how hard is it to pull that tranny apart I'm pretty good with my mechanical ability ,I have changed heads and cam on truck already so I'm thinking of tackling the tranny myself
Old Nov 24, 2015 | 10:51 PM
85e150's Avatar
85e150
Check the shift fork!
Not too hard to pull one apart, just make sure you note the order of everything. You may need a puller and/or press for some bearings.
You should be able to find a rebuild guide on line. Should.
Old Dec 17, 2015 | 08:12 PM
coffeedog's Avatar
coffeedog
It sounds like you can make it work, but it will be a lot of work. I have a friend and that's what he does, takes engines and transmissions from vehicles that run but the body is crap, and swap them into vehicles that don't run for those reasons. Makes a decent living.
crazymut
Nov 29, 2009 08:05 AM
marcmckenzie
1997 - 2003 F150
Sep 6, 2004 04:33 PM
rez2
Jun 11, 2004 03:51 PM
mudbath
Mar 22, 2004 04:50 PM
