Pcm case ground
Old Nov 24, 2015 | 02:05 PM
DocV8's Avatar
DocV8
Pcm case ground
I have pcm case ground at 30,71 volt with car gauge pro ---
see my post with my big idm problem
please help
Old Nov 24, 2015 | 02:14 PM
jhl3's Avatar
jhl3
Are you stating that you are seeing 30.71 VDC at ground on the PCM?
If yes, could you verify this with a standard volt/ohm meter?
Has anyone removed or changed the wiring on your batteries? If yes, make sure they are not in series and being charged.
Old Nov 24, 2015 | 02:24 PM
DocV8's Avatar
DocV8
If so, could you verify this with a standard volt/ohm meter?
Has anyone removed or changed the wiring on your batteries? If so, make sure they are not in series and being charged.
On case there's 0 ohm to ground - my batteries are not in series - they are parallel --- my right side dies on the road
Old Nov 24, 2015 | 02:29 PM
jhl3's Avatar
jhl3
please help
OK. Please explain the "30,71 volt" from above.
OK.
Are they being charged?
Old Nov 24, 2015 | 02:40 PM
DocV8's Avatar
DocV8
OK.
Yes both are full -----
Old Nov 24, 2015 | 02:42 PM
DocV8's Avatar
DocV8
OK.
I have seen the 30.71v in car gauge pro and don't understand why
Old Nov 24, 2015 | 02:48 PM
jhl3's Avatar
jhl3
Maybe the car gauge pro is incorrect. Do you have a standard volt/ohm meter that you can use to verify the reading.
Old Nov 24, 2015 | 02:55 PM
DocV8's Avatar
DocV8
Yes -- --- the case voltage is 0v to ground but other posts I see sometimes 14 to 16 volt ???
Means case ground not 0v to ground ???
Old Nov 24, 2015 | 08:27 PM
Pikachu's Avatar
Pikachu
I'm pretty sure there's no PID for "PCM case ground." Just because it exists in Car Gauge Pro, doesn't mean it's relevant.
Old Nov 25, 2015 | 05:25 PM
Zwalters's Avatar
Zwalters
Grounds generally should be 0 Ohm or way less that 1 ohm (I don't get worried on automotive grounds showing a 0.1 ohm resistance, most of the time you get resistance on ground checks, it's due to surface corrosion, clean and repeat). If you have 0 vdc from anything that should be grounded to ground is good, means there is no potential voltage between the two measurement points. It's like measuring on the same post on the battery, no voltage potential exists. Grounds should read 0 vdc when checked to other grounds unless they are isolated grounds or different circuits, I don't know of any of those type circuits in our trucks.
Old Nov 26, 2015 | 07:29 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
^^what Z said^^
powerstroker100
Apr 15, 2025 03:14 AM
knotreel
Aug 10, 2019 02:45 PM
PNW350SD
Oct 4, 2016 03:24 PM
my93
Dec 23, 2010 03:40 PM
