Huh, now that's interesting. Just took a look at the order guide and found this:
Looks like if you live in Alaska or the upper midwest it's standard, all other states need not apply. Very interesting.
I've never seen one work that way, but the only ones I've had before were on diesel models. But every one I've ever owned or read about is comprised of a heating element that replaces one of the block casting plugs and is immersed in coolant. I'll have to do some more digging, but I'm assuming that's what this one is.
ENGINE BLOCK HEATER
Standard and only available in the following states: AK, MN, ND,
SD, MT, WI and WY. Other states available via FCSD.
NOTE: (Fleet Only) – Engine block heater (41H) available in all
states with valid FIN code.
Well, that's why my 2013 has a block heater. (It was sold new in WI) I live in IL. I bought the truck in WI. it spent its winters in AZ. I do not plan to drive this one in the salt.
They are common here in Northern Minnesota, The Eco uses a immersion type heater, It screws into the block cooling jacket, most are 400 watts on gas engines,
Most of the newer cars are also equipped with a thermostatic cord so the block heater won't turn on until the cord temp is around 5 to 10 degrees, I suppose it saves energy.
Here it Zero-Starts catalog, this is the brand most use up here. Phillips & Temro Online Parts Catalog
Very interesting speedsauto, I didn't know something like that was out there. I just checked the owner's guide, and it looks like these don't use a thermostat.
Originally Posted by 2015 Owner's Guide, p 162
Using the Engine Block Heater
Make sure the receptacle terminals are
clean and dry prior to use. Clean them with
a dry cloth if necessary.
The heater uses 0.4 to 1.0 kilowatt-hours
of energy per hour of use. The system does
not have a thermostat. It achieves
maximum temperature after
approximately three hours of operation.
Using the heater longer than three hours
does not improve system performance and
unnecessarily uses electricity.
It's a shame Ford didn't come up with a way to circulate coolant (even slowly) when the heater is plugged in. That would move heat throughout the motor and make the heater a lot more effective...
What's different on the gas elements versus the diesels? My 6.0 coolant will be 100f after 4 hours plugged in. The heated coolant will naturally "circulate"
The Diesel just has a larger heating element, It has to warm up much more coolant then the gas engine has, the gas is the same, If it was plugged in all night the heater was blowing heat right away. 400 watts is plenty down to the -45 we see up here anyway.
I was being facetious, but I am assuming the smaller element isn't heating as well as the 900 watt Diesel elements.
Even still, the 6.0 block heater only raises the coolant a certain amount over ambient.
I have heard of such systems for use on heavy equipment. they generally have a pump and a diesel-fired heater from what I've seen. I don't think that's a common system anywhere but the arctic, and even there, if it's truly cold, those machines will run 24/7 until the job is done.
Back in the day when I lived up in north-central Minnesota (near Brainerd), everyone used circulating tank heaters. It was a small unit a little larger than a Fosters beer can. You hook it into one of the heater hose lines, and it heats and circulates the coolant.
We had a non-heated garage, but we rigged up a timer that would turn on all the tank heaters at OH-dark:30.
It was wonderful to be able to turn on the heat in the vehicle and get warm air from the git-go. Backing out of the driveway, I would already be warm, but I still had the square tire problem until those old nylon-chord tires started warming up.
Hm, depending on electricity rates in some areas it may be almost cheaper to let it idle all night.
Bullitt...you don't have to do any retrofitting to your 5.0, just order a block heater from Ford and install it. I live in North Pole Alaska, all of the vehicles have block heaters, battery pad heater, oil and transmission pan heaters. When it's 50 below it's tough on a vehicle. But almost all the garages here are heated so we don't plug in at home.
That's what I meant, purchase the block heater and cord from Ford.
