1978 - 1996 Big Bronco
electrical issue
Old Nov 22, 2015 | 03:17 PM
Nicolas Lopez's Avatar
Nicolas Lopez
electrical issue
I Have a 93 ford bronco 4x4 with a 351 windsor and the e4od tranny it does great on road but when we jump her in the dunes all day she shuts down like no fuel issue but its not a fuel issue its a heat issue cant figure out any suggestions on where to start
Old Nov 22, 2015 | 04:28 PM
Thunderhorn's Avatar
Thunderhorn
Why does the title say electrical issue if you think its a heat issue? what do you mean its a heat issue? Is it getting too hot and ceasing up? what do you mean "shuts down"? Stop driving it if it is ceasing due to heat, you're gonna blow the head gasket or break something worse.
If it is simply overheating, try flushing the cooling system with some sea foam and new water/coolant a few times. check thermostat, radiator flow, make sure your fan is blowing, fan clutch is working if you have one. if all that fails, then you might just be driving too hard for a stock radiator.
If it is an electrical issue that happens when it is hot, could be a spark advance issue, MASS air flow, EGR, ect... too many to list on a computer controlled bronco. however that also means it should be throwing a code.
But yeah, why do you say its a heat issue? more info would help.
Old Nov 23, 2015 | 12:30 AM
g_k50's Avatar
g_k50
rebuild distributor
Old Nov 23, 2015 | 01:27 AM
Nicolas Lopez
It runs great, doesn't over heat or throw codes. But after running it hard, steep hills, offroading it starts bogging out. Once it starts acting up, won't hold idle n eventually after trying to turn over many times just won't start until it's sat for couple hours. Can drive around town great, no problems, the minute i start to play 4x4, offroad, mud, sand etc it starts acting up again. I say heat issue because its like something gets warm, sensor, just can't figure out. Already rebuilt distributor cap, new throttle position sensor, ignition coil, idle control valvle, new relays, change spark plugs, new fuel pump n fuel filter. Any suggestions???
Old Nov 29, 2015 | 09:53 PM
Black Ford XLT's Avatar
Black Ford XLT
Nicolas , when u say steep hills, I wonder if it could be your inertia switch acting up. Ford installed these in case of roll over (fire).It cuts the fuel off. Its located in the kick panel passengers side. Good luck TR
Old Dec 6, 2015 | 10:58 PM
g_k50's Avatar
g_k50
I suggest you rebuild the distributor, new everything that's replaceable, stator, pip sensor, ICU etc.
ihateminimumwage
15
Feb 21, 2022 06:06 PM
tomwhatley
Sep 1, 2014 09:57 PM
jehuie
1997 - 2003 F150
Jun 19, 2011 09:38 AM
HarryPutnam
29
May 16, 2011 12:31 PM
zigzagn
Sep 4, 2003 06:23 AM
