Carb Question
Old Nov 22, 2015 | 12:40 PM
Adam Woolridge's Avatar
Adam Woolridge
Carb Question
My Holley 1904 developed a leak at the bowl, so I got a new gasket and it still leaks. I noticed that there are two lock washers on each of the 4 screws. There is one at the head of the screw and another that's between the bowl itself and the carb body. Are those supposed to be there? They don't show on exploded parts views. It seems these washers are keeping me from tightening it a the way down.
Old Nov 22, 2015 | 01:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Old Nov 22, 2015 | 01:26 PM
Adam Woolridge
Thanks Number. That's the exploded view I was referring to. Just to confirm, there should be no lock washer between the bowl (98507) and the body (9512), only on the outside of the bowl? The extra ones I'm referring to are right where 9512 is pointing. One lock washer per screw? I just want to make sure I'm seeing it correctly.
Old Nov 22, 2015 | 02:53 PM
shipwrecked's Avatar
shipwrecked
hey- check out mikes carburetor on youtube. he does a 4 video rebuild on this carb.
Old Nov 23, 2015 | 10:39 AM
JimKoz's Avatar
JimKoz
There should not be any washers between the bowl cover and the body of the carburetor. Someone probably thought that adding them would prevent the cover from being overtightened and warping it.
Old Nov 23, 2015 | 10:48 AM
Adam Woolridge
Took the washers out and made a cork gasket. Seems to be holding. Thanks for the help.
Steves55
Nov 13, 2017 11:00 AM
rustyjones14
Dec 16, 2013 11:11 AM
jasonmerlo
Apr 21, 2007 04:27 PM
SENOJ36
Aug 1, 2003 12:01 AM
tetraruby
Jul 14, 2002 02:47 AM
