Modular V10 (6.8l)
Ex wouldn't start
Old 11-20-2015, 05:59 PM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
Ex wouldn't start
Ex wouldn't start this AM, tried many times would only crank. 41 psi at rail with key on, no codes, all doors fully unlocked.
Put my foot to floor and it started with big cloud of grey smoke. What's the deal? Thought I'd come to the brethren for opinions!
Old 11-20-2015, 06:30 PM
dougger222's Avatar
dougger222
dougger222 is offline
Guessing diesel?
Plugged in?
Glow plug and glow plug relay/module been replacement lately?
What temp?
Of my four 7.3's only the dually don't start good in the cold not plugged in. When it's really hard to start will have to lay into the diesel pedal to get it to fire and keep on it until it catches. That truck has had the following replaced and or checked to ensure is working properly, batteries, glow plugs, glow plug relay, injectors, hpop (new adrenaline), and all battery connected tested. Starting to the think it's the PCM. The SRW years ago was a bear to start and we took the one out of the dually and that starts fine unplugged down to -10.
Old 11-20-2015, 06:36 PM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
Originally Posted by dougger222
Guessing diesel?
Plugged in?
What temp?
Actually v10 gasser.
Old 11-21-2015, 10:15 AM
harley4jcs's Avatar
harley4jcs
harley4jcs is offline
2 possibilities are key chip (do you have another key) or the CPS...You'll have to have more test times to see if the pedal had anything to do with anything
Old 11-21-2015, 11:48 AM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
Where is cps?
Old 11-21-2015, 02:25 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Moved over to the 6.8L V10 forum.
Stewart
Old 11-21-2015, 02:34 PM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
Would iac do this? Seems to only do it when cold. Did again today had to keep on gas pedal to keep it running.
Old 11-22-2015, 01:45 PM
BroncoRN's Avatar
BroncoRN
BroncoRN is offline
It was cps! I removed 2 10mm bolts on ac compressor, pivoted it out of way and replaced sensor. Works great now.
Old 11-25-2015, 07:51 AM
harley4jcs's Avatar
harley4jcs
You can send the REPs my way anytime now.
kt19
21
01-09-2014 11:17 AM
n.o.yat
10-22-2008 05:19 PM
backhoeken
07-08-2007 11:23 PM
hdman6
02-19-2007 01:02 PM
generalee31184
24
12-29-2006 04:55 PM
Quick Reply: Ex wouldn't start
