flywheel ring gear
Old Nov 19, 2015 | 08:14 PM
fordbroncodave's Avatar
fordbroncodave
flywheel ring gear
I got a foul starter for my 96 f350 and all it does is grind. To remedy the situation i put it in 5th gear and shove the bumper to rock the truck then it starts. I am tired of doing this and its time to fix it.
I cannot figure out what ring gear i need. 5 speed zf. I believe it has the dual flywheel too.
Starter is under warranty if need be if the bendix gear is bad too but the ring gear is bad.
Can i flip it over and use the other side ofthe gear?
Old Nov 19, 2015 | 09:00 PM
BuckHammer's Avatar
BuckHammer
If you have a dual mass flywheel, you should consider replacing it with a single mass flywheel.
qman
Jun 3, 2015 04:21 PM
5150 fear
13
Jun 10, 2014 10:21 PM
Aune163rd
16
May 6, 2011 09:43 AM
lifted79ford
Mar 26, 2008 11:30 PM
Midnite Cruiser
Jun 13, 2003 07:57 AM
