starter ring gear
Old Jun 10, 2003 | 02:56 PM
Midnite Cruiser's Avatar
Midnite Cruiser
Question starter ring gear
Having confirmed that the 312 flywheel is a one-and-only item NOT swappable with the other Y's, I am about to get put back together properly BUT:
THere are a couple short teeth on the ring gear on that 312 flywheel, and that 239 ring gear is cherry.
ANY reason not to swap it onto the 312 flywheel???
Old Jun 10, 2003 | 03:32 PM
phjbbu's Avatar
phjbbu
starter ring gear
Ring gears can be changed.
Old Jun 12, 2003 | 07:14 PM
286merc's Avatar
286merc
starter ring gear
Do you have a part # off that flywheel? If what you say is true of ALL 312's then there is a lot of wrong data published over the years.
Old Jun 13, 2003 | 07:57 AM
Midnite Cruiser
starter ring gear
Sorry, I looked all over both flywheels and could find no number marking s at all. It did look like the balance points were at a different point on the clock though.
