Alternator Regulator
Old Mar 12, 2006 | 08:14 PM
jboard's Avatar
jboard
Exclamation Alternator Regulator
Does my 90 have an external voltage regulator for the alternator? if so then where is it located. The alternator is a 100 amp with 4 connections: Ground, Positive, and a plug with 2 wires in it. I noticed that my volt gauge has been real low until i rev it up to about 1500rpm then the voltage comes up. my alternator is only about 2 months old.
Jeremy
Old Mar 12, 2006 | 08:21 PM
dieself250's Avatar
dieself250
you got an external regulator its on the passenger side fender,its a metal square box with a flat plug on one , i think it has 4 or 5 wires off of it ,look right behind the battery cant missit. on some of my trucks i will go through a "lifetime rebuild" alternator every 6 months
Old Mar 12, 2006 | 09:07 PM
jboard's Avatar
jboard
ok thanks thats what i thought it was
Jeremy
